FTTP Speeds:
- Full Fibre
- Re: FTTP Speeds:
FTTP Speeds:
04-03-2015 4:40 PM
This is the kind of speed i am getting at the moment.
http://www.speedtest.net/result/4188571898.png
Re: FTTP Speeds:
04-03-2015 4:42 PM
Re: FTTP Speeds:
04-03-2015 4:48 PM
Re: FTTP Speeds:
04-03-2015 4:50 PM
Re: FTTP Speeds:
04-03-2015 4:53 PM
Re: FTTP Speeds:
04-03-2015 4:55 PM
Also try this speed test - http://www.thinkbroadband.com/speedtest.html
Re: FTTP Speeds:
04-03-2015 4:57 PM
Re: FTTP Speeds:
04-03-2015 5:03 PM
Re: FTTP Speeds:
04-03-2015 5:04 PM
Re: FTTP Speeds:
04-03-2015 5:16 PM
Double check your IP Profile here in case something has become messed up.
Re: FTTP Speeds:
04-03-2015 5:25 PM
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Re: FTTP Speeds:
04-03-2015 6:10 PM
Re: FTTP Speeds:
04-03-2015 6:14 PM
Re: FTTP Speeds:
04-03-2015 6:31 PM
Re: FTTP Speeds:
04-03-2015 6:34 PM
