FTTP Speeds:
- Full Fibre
- Re: FTTP Speeds:
FTTP Speeds:
24-12-2014 10:51 PM
Re: FTTP Speeds:
30-12-2014 1:20 PM
Re: FTTP Speeds:
30-12-2014 1:22 PM
Re: FTTP Speeds:
30-12-2014 1:32 PM
Re: FTTP Speeds:
30-12-2014 1:45 PM
Most people are happy with 80/20 as that meets their needs and requirements.
Re: FTTP Speeds:
31-12-2014 3:03 PM
Re: FTTP Speeds:
31-12-2014 3:37 PM
If you want to extend wireless range then a secondary router/access point connected to your primary router with Ethernet is the best option, failing that use homeplugs
Re: FTTP Speeds:
31-12-2014 4:22 PM
Re: FTTP Speeds:
01-01-2015 5:06 PM
Re: FTTP Speeds:
01-01-2015 7:18 PM
Re: FTTP Speeds:
01-01-2015 9:09 PM
Quote from: tomxlisa Just been and took the extenders back and got some homeplugs which has sorted the problem straight away, getting full speed now, but still only getting about 30Mb on the wireless devices (mobile phones/tablets) i guess there is no way of sorting them so they get full speed too?.
Have you looked at the frequency you are using?? I had a similar problem in that my router was on the same channel as a neighbour. Changed to a vacant channel and speed increased.
Re: FTTP Speeds:
01-01-2015 10:26 PM
