FTTP - Can I have an invite to the trial please?
- Full Fibre
- Re: FTTP - Can I have an invite to the trial pleas...
24-01-2011 9:29 PM
I just signed up with Plusnet leaving an ISP that I was very happy with in order to get on the FTTP trial, I live in Monkston Park and I am on the Bradwell Abbey exchange in Milton Keynes. Please send me an invite to the trial?
Thanks,
Ross
Re: FTTP - Can I have an invite to the trial please?
25-01-2011 1:41 PM
Welcome to Plusnet and the forum, if you go to http://trials.plus.net and login with your new Plusnet username and password you'll be able to raise a ticket to take part in the FTTP trial which will go through to our trial team who'll place the order once you've moved across to us.
Plusnet Technology
26-01-2011 11:40 AM
Quote 30. Is the trial available to everyone in the trial areas?
BT may need to do a site survey to see if you can get the service and multi-dwelling units like flats and some multi unit commercial properties will be excluded.
I just found this in the FAQ, when I called the sales team to switch to plusnet I mentioned I was in a first floor apartment and was told it wouldn't be a problem, does this mean I definitely won't get on the trial?
26-01-2011 11:48 AM
Plusnet Technology
26-01-2011 11:59 AM
Thanks for the quick reply, sorry I'm not sure I understand the question, it's a block of 5 flats, 2 ground, 2 first floor, 1 second floor, I'm on the first floor...I have a dish for sky HD so it won't be a problem to put a hole in the wall and 20m should be plenty to route the fibre from the ground level outside.
Is that what you meant?
Regarda,
Ross
26-01-2011 3:43 PM
Plusnet Technology
26-01-2011 3:47 PM
10-02-2011 10:58 AM
I feel a bit cheated and that if i had have got a different engineer he would hae done the work, he could have done it just didn't want to...do you have any information about a new trial for flats in July? is there anything else i can do or try?
Reards,
Ross
10-02-2011 3:19 PM
10-02-2011 4:58 PM
That's a shame, because the line check said it was OK I was hoping they'd be able to do it. I have had an update from BT about the trial in flats and I've already put your name forward, waiting to hear when it'll be, I'm hoping sooner rather than July.
Plusnet Technology
30-04-2011 12:55 PM
i have recently moved home and i'm now living in a house on postcode MK3 7NU. i beleive at this address i can have FTTC. Do i have the sort of package I can migrate to my new address and get onto FTTC or an FTTP trial?
apologies if this isn't the right plae to ask but i already had a thread open.
Ross
30-04-2011 3:34 PM
FTTP is still in trial, and so are FTTC products for business.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
- Full Fibre
