FTTP BT Speedtester
dave
Fixes: 4
FTTP BT Speedtester
Hi guys,
Could a couple of our FTTP customers give the BT speedtester a try please:
www.speedtester.bt.com
and let me know if it works. If it doesn't can you let me know where it fails (I'm suspecting the page when you put the phone number in).
Thanks,
Dave Tomlinson
Plusnet Technology
15 REPLIES 15
PaulStunt
Re: FTTP BT Speedtester
Hi Dave,
For me it was as you suspected and it fails on the page where you put in your phone number.
It returns an error and to raise it with my ISP.
Paul
dave
Fixes: 4
Thought so ta, looks like you need to enter the Service ID, I'll PM you your service ID if you could try that, would be appreciated.
Dave Tomlinson
Plusnet Technology
PaulStunt
Using the Service ID worked fine.
Not sure if you want the actual results as I am assuming you are testing the tool and not the speeds.
Just shout otherwise.
Paul
dave
Fixes: 4
Yeah just testing the tool out, thanks. Just means that I need to ensure that anyone that wants to run the speedtest on FTTP needs to know what their service ID is. I'll add this to my list. If anyone else wants to run it let me know and I'll PM you the service id. Thanks Paul, appreciated.
Dave Tomlinson
Plusnet Technology
PeterPan
Dave,
I'd be interested to use the BT tester and compare results with speedtest.net.  Can you PM me my Service ID, please?
Peter
bluewhale
oops sorry wrong thread
gkstone
Dave,
I would be interested in using the speedtest as well please if you could send me the sevice ID.
champson
same here, could you let me know my service ID,
thanks, Chris.
dave
Fixes: 4
Will pick them up tomorrow.
Dave Tomlinson
Plusnet Technology
dave
Fixes: 4
Both sent via PM.
Dave Tomlinson
Plusnet Technology
rtjones2
Dave,
I also fancy trying out the BT speedtest
champson
Test results at 19:00 Fri 08/10/10
PeterPan
Dave,
The BT Speedtester seems to work OK (provided you use the Service ID - Thanks for supplying it)
The only disadvantage seems to be that you can only use it once per hour, so you can't do repeat tests to look at behaviour over short periods of time.
Test result at 17:52 GMT on Saturday 09/10/10:
Download  77.083Mb/s
Upload 12.799 Mb/s
Test result at 20:00 GMT on Saturday 09/10/10:
Download 65.920 Mb/s
Upload 13.366 Mb/s
Peter
dasx199
Installed! If you could PM me my service id that'd be awesome.
