FTTP Availability
DaveCW
Re: FTTP Availability
I will get back to you friday AM and hopefully we can track this down.
Fixes: 1,600
Sounds good, let us know when you're free
DaveCW
Hi Gandalf, I am free to start testing just now.
As I don't experience the fault at my end (Phone works, internet working no noise on the line) it will need you chaps to re test at each stage.
Fixes: 1,600
Hi Dave,
That's cool. So far we've tested under the following conditions, let me know if I've got anything wrong.
Everything setup as normal - Loop fault
Modem plugged into test socket with microfilter - Line is clear
Faceplate back on with extensions disconnected - Loop fault
Can you connect all your equipment into the test socket? This should just take the faceplate out of the equation.
DaveCW
Hi Gandalff,
Ok so I have removed the faceplate,
Micro filter to Master socket,
modem to Filter,
phone & Alarm to in to Phone doubler in to Filter
Fixes: 1,600
Hi Dave,
Unfortunately we're still seeing that loop fault again, I suspect the additional equipment you've got into the filter may be causing it. Can you disconnect the phone doubler and alarm, putting your phone handset directly into the microfilter?
DaveCW
Hi Gandalf
Doubler removed only phone direct to Micro Filter
Fixes: 1,600
Thanks Dave,
Sorry about the delay there, the loop fault is still present.
Before concluding it's your phone handset, could you disconnect that from the filter? I'll then retest your line again.
DaveCW
Phone disconnected, just filter & Modem connected now
Fixes: 1,600
And there's now no fault showing. It doesn't seem that your handset is actually affecting your service though apart from causing a loop condition/form of short circuit.
DaveCW
Could I ask you to test one last time, I have removed the call blocker and put the phone direct to the filter. That way i know it is either definitely the phone or the call blocker
Fixes: 1,600
Sure, no problem. There's no fault showing, looks like it may have been the call blocker?
DaveCW
Hi Gandalf Thanks for you help, it is much appreciated.
I now know what was causing a problem and what to do about it,
Fixes: 1,600
Hi Dave, that's cool no problem.
Feel free to let me know if there's anything else you'd need help with.
Mav
Fixes: 515
Moderator's note by Mike (Mav): The fix has been changed to @Gandalf as per message #27.
Forum Moderator and Customer
