FTTC upgrade complete, download speed still low but upload speeds huge!
- Full Fibre
- Re: FTTC upgrade complete, download speed still lo...
07-12-2010 12:01 PM
My connection was upgraded to FTTC yesterday lunchtime, and the install went smoothly so no complaints there.
The Openreach engineer showed me that the line was synching at 40Mbps down and 10 Mbps up, but when I connected through to Plusnet, the download speed was only 3.5-4Mbps. (Upload speeds are fantasically improved - up from 300kbps to about 8Mbps).
Is there something that plusnet need to tweak in terms of IP profile so that I can get the increased download speeds promised?
I have added comments to my initial ticket with the same information - ticket ref is 37167246.
Thanks,
Mike
Re: FTTC upgrade complete, download speed still low but upload speeds huge!
07-12-2010 1:08 PM
Is your upload still great but download the same as before?
Ta.
07-12-2010 6:00 PM
as you mentioned its most likely related to your PN profile which just needs to be uncapped. (as with mine initially)
07-12-2010 7:24 PM
Mike
07-12-2010 7:51 PM
07-12-2010 8:27 PM
Perhaps I selected the wrong option on the call menu system!
Hopefully someone will spot the comments on the ticket soon, as I am so close to faster broadband but just not quite there yet!
(Although the faster upload speed should help enormously if we ever get sufficient snow that I need to work from home again).
Mike
08-12-2010 7:49 AM
08-12-2010 8:08 PM
It should be fixed at 20000, if it's not then PN have not put you on the FTTC profile yet.
Note: the 20000 profile is a special one to allow full speed on FTTC.
09-12-2010 6:35 AM
Speeds appear to be improving - and will hopefully continue to increase as the pre-upgrade estimate was for about 29Mbps.
Mike
10-12-2010 11:04 AM
I can see what the Netgear router is doing, but that's only the 100M ethernet link between itself of the modem!
I suppose I could always plus a computer directly in to the LAN port of the modem, but this strikes me as slightly risky from a firewall perspective!
Regards,
Mike
10-12-2010 3:26 PM
http://community.plus.net/forum/index.php/topic,90976.0.html
Don't get excited
11-12-2010 7:08 AM
My standard setup involves a homeplug network between the router and my desktop pc (the master socket inconveniently comes into the house in a cupboard a long way from anywhere useful).
This morning I tested a directly wired connection between my work laptop and the router, which gave speeds of about 39Mbps download and 8 Mbps upload - which is more or less perfect.
I am now left with two choices (given that I am not about to rip up floors and drill through walls to install ethernet cabling):
1 - upgrade to homeplug AV, which should improve speeds across the ring main
2 - wait a few days until I get my (previously ordered) new computer with its built in wireless-n card and try that instead of homeplug. (I though that it was about time I upgraded, as my current PC is about 8 years old now, and beginning to show its age a little.)
I suspect that I will try option 2 first, and see how that goes before thinking about spending more money at this time of year!
11-12-2010 8:46 AM
How far away are you from the router and how many walls / ceiling are between yo and it? Wireless N does have improved range but it does depend on how many walls it has to go through, and how those walls are build (brick / plasterboard etc).
12-12-2010 10:21 PM
I think that I will wait until next week to see how the wireless-n does before trying anything else.
If that's no good, then its a choice between paying for homeplug AV or a master socket shift (both about the same price, I think!)
17-12-2010 10:24 PM
Hopefully the wireless signal will be even better when I put the PC here (need to do a bit of backing up and file transfer before I decommission this one).
Generally quite pleased with the result - certainly better than I was getting via the homeplug - although it could be that the 8 year old PC is also a limiting factor.
MIke
- Full Fibre
