FTTC trial - update on joining
- Full Fibre
- Re: FTTC trial - update on joining
01-02-2011 3:12 PM
Wondered whether any Plusnet people can give me an update on where my application is up to.
Ticket 38998165 posted on 19th January
Reply on 25th January - Our pre-order checker is currently down, we'll try to place your order again shortly
Not had any update since. As tomorrow is two weeks from posting my ticket I wondered if there is any news.
Message 1 of 8
(1,782 Views)
7 REPLIES 7
01-02-2011 4:08 PM
I too had an update on 25/1 with same problem. This was the case on the 27th too so would be curious to know if this is fixed yet. I understand they have/had 100 applications to go through so will get there eventually.
Message 2 of 8
(736 Views)
03-02-2011 11:56 AM
I'm still waiting too. I asked for an update on my ticket yesterday, but nothing as yet.
Message 3 of 8
(736 Views)
03-02-2011 6:10 PM
Just been updated so appointment booked
They have to put the trial on the back burner until their normal workload is dealt with as this is a 'trial' so they will get round to you and no set time response as to when they will reply to a request to join.
HTH
HTH
Message 4 of 8
(736 Views)
03-02-2011 6:48 PM
Same here update this evening and appointment booked
Can't wait having had to suffer up to 1m max speeds for the last 7 years.
Message 5 of 8
(736 Views)
03-02-2011 7:59 PM
Glad to hear it! A 38x increase for you then? Not as bad for me as 6.5Mbps data rate after overheads removed currently, but a 6x speed still exciting enough!
Message 6 of 8
(736 Views)
04-02-2011 10:47 AM
Still waiting for a reply on mine - Question #39434960
I did only place it a few days ago though, I have been on 2 meg forever! Predicted speeds of 38 meg!!
Message 7 of 8
(736 Views)
04-02-2011 1:29 PM
You might get lucky but my request was on 18/1/11 and was initially dealt with on 25/1/11 but halted due to technical fault with the line checker.
Message 8 of 8
(736 Views)
- Full Fibre
