FTTC installed
- Full Fibre
- Re: FTTC installed
FTTC installed
28-01-2011 9:19 AM
Message 1 of 5
(1,310 Views)
4 REPLIES 4
Re: FTTC installed
28-01-2011 9:27 AM
Message 2 of 5
(613 Views)
Re: FTTC installed
29-01-2011 7:37 AM
Message 3 of 5
(613 Views)
Re: FTTC installed
29-01-2011 9:34 AM
If you don't have a 20Mb plusnet profile set under high speed broadband then you are not on the FTTC profile and speeds will be lower. You need to pester PN to get the correct profile set.
Message 4 of 5
(613 Views)
Re: FTTC installed
29-01-2011 11:38 AM
Thanks Peter
Anyone from Plusnet out there?
Message 5 of 5
(613 Views)
