FTTC box overheating
- Full Fibre
- FTTC box overheating
Re: FTTC box overheating
30-08-2011 12:59 PM
Quote from: Alex
Your support ticket has been updated. As per the ticket we will need to monitor the line over the next 24 hours to allow the DLM reset to complete which the engineer initiated. I will contact you tomorrow if any further action is required.
Thanks Alex.
30-08-2011 1:57 PM
Quote from: Baldeagle1
Hi Dev,
I started a forum thread here:-
http://forum.kitz.co.uk/index.php/topic,9726.0.html
Are you suffering regular disconnections/reconnections?
Paul.
No, my connection is stable, it was also stable for 1 month before the modem was changed. 3 engineer visits have found no faults on the line, I am mystified as to why it cannot resynch at the original speeds. I did a reboot on Sunday to activate PlusNet firewall, apart from that there has been no drops except for the engineer visits. I had a stable Plus Net connection for over 3 years at 16Mbps on ADSL2+.
Today
May
30-08-2011 2:35 PM
I would recommend for you to raise a fault at http://faults.plus.net/ for investigation. Your line speed is indeed much lower that your line speed estimate.
30-08-2011 3:11 PM
Quote from: Alex Hi Dev,
Hello Alex, I had a ticket open since 19 July which was only closed last week, 3 engineers visit have found no faults on my line. I am not sure what more can be done unless they receive clear instructions from PN.
30-08-2011 3:18 PM
30-08-2011 5:06 PM
I have raised a new ticket #46052400
31-08-2011 9:59 AM
I've passed the ticket to our fibre faults team who will be in touch shortly.
Quote from: Dev Is it possbile for PN to reset my IP to 37 so that there will be no conflict of IP for when the engineer resets the BT one?
With our fibre products all our profiles remain fixed at the maximum rate. No automatic adjustment occurs unlike our ADSL based products so no such adjustment will be required.
31-08-2011 11:08 AM
Quote from: Alex Hi Bald_Eagle1,
Hi Alex,
I have updated my help ticket & the Kitz forum.
There has been a slight improvement since yesterday, but my profile still appears to be stuck at around 24 Mb, as per when BT reset it a few engineer visits ago.
What's next on the agenda?
Paul.
31-08-2011 12:35 PM
"16.2M-32.4M Downstream, Interleaving Off - 0.5M-2M Upstream, Interleaving Off"
Which allows a sync rate up to 32.4Mbps but your line is only achieving 23.98Mbps. I suggest that you monitor your speed over the next few days to allow the speed to pick up.
31-08-2011 12:47 PM
Quote from: Alex
Thanks Alex,
Would you recommend a reboot of the modem to pick up a new sync speed?
Paul.
31-08-2011 12:55 PM
05-09-2011 10:25 AM
I have updated Plusnet ticket #45613819 as no speed improvement has been noticed by this morning (5th September), although the line does now appear to be very stable.
Paul.
dick:quote
06-09-2011 9:26 AM
I've just given Alex a nudge, he should be updating you later on as to what's going on.
06-09-2011 9:44 AM
I noticed that Alex hadn't made any forum postings yesterday, so I presumed he wasn't in work & I wasn't going to try to nudge things along until today.
Paul.
07-09-2011 9:34 PM
