FTTC booked for next week - any issues with own equipment?
- Full Fibre
- Re: FTTC booked for next week - any issues with ow...
09-02-2011 9:29 AM
I've got my FTTC swap booked for next week. I plan on using my own equipment into the BT VDSL modem (it supports PPPoE). Are there any issues I ought to be aware of? Also, I'm on a static IP. Does anyone know if I should be able to keep the same IP when I change over?
TIA
TIA
Message 1 of 7
(2,132 Views)
6 REPLIES 6
Re: FTTC booked for next week - any issues with own equipment?
09-02-2011 10:39 AM
I kept my static IP ok when I switched over to the FTTC trial.
Message 2 of 7
(780 Views)
09-02-2011 10:45 AM
That's good news - thanks, Picnic
Message 3 of 7
(780 Views)
09-02-2011 3:16 PM
You need to watch out that your router has enough grunt to handle the throughput.
I have a router that can only manage 12Mbps (all wired) so it's not much use with a fibre connection.
Message 4 of 7
(780 Views)
09-02-2011 3:53 PM
My vigor 2820n works fine with it. Full speed on wired LAN. Nearly full speed on WLAN (11n), with a following wind
All the features of your package should remain unchanged.
Message 5 of 7
(780 Views)
09-02-2011 5:06 PM
I've actually got a Vigor 2920 for that reason
It should have enough grunt. It's replacing a Cisco 877. I'd have liked a Cisco but couldn't justify the cost of something with a fast enough backplane.
Message 6 of 7
(780 Views)
09-02-2011 5:30 PM
Quote from: brassedoff I've actually got a Vigor 2920 for that reason
Oh, heck yes, that should do it no problem.
Message 7 of 7
(780 Views)
- Full Fibre
