FTTC Thomson TG585vn router for testing
- Full Fibre
- FTTC Thomson TG585vn router for testing
Re: FTTC Thomson TG585vn router for testing
03-09-2010 12:32 PM
03-09-2010 1:25 PM
John - WPS is probably switched on, might be worth doing a factory reset, switch it on and hold the pin in for 7 seconds at the back. If it loses the FTTC config I'll send you the firmware over to reflash.
Plusnet Technology
03-09-2010 5:40 PM
so seems like somehting isn't working ok
will do some more investigation over the weekend
03-09-2010 6:54 PM
is this normal for a g type?
going to try and config my netgear as a bridge onto it later see how that does
03-09-2010 8:31 PM
Plusnet Technology
03-09-2010 8:48 PM
Dave - I'll try a factory reset, and get back to you.
03-09-2010 9:07 PM
03-09-2010 9:32 PM
Then it stopped responding. Following a restart of the router (I didn't touch the modem) I'm back on.
Is it possible that all the messing around - turning routers and modems on and off etc - has affected the profile?
03-09-2010 9:49 PM
Sync Status In Sync
Downstream Speed 39.999 Mbps
Upstream Speed 9.999001 Mbps
So don't think it's affected the speed by switching routers and rebooting. Let's see if the_norris gets chance to try his router out, they're both exactly the same, we flashed them with the same firmware then go back to Thomson on Monday and see what they say.
Plusnet Technology
03-09-2010 10:05 PM
03-09-2010 10:31 PM
thats an awful drop and was same right next to the router
i haven't tried with no security on though
so how is the n version then faster?
03-09-2010 10:36 PM
I'm hoping the speed will pick up as it settles in - and hopefully it will stop dropping the connection as well
03-09-2010 11:51 PM
When it does work, it seems to work well. Although speeds seemed slow for an N router (could that have been because my desk top was operating in g?)
Let me know if I can try anything else
04-09-2010 10:03 AM
Quote from: bluewhale hmm. not convinced by the overheads argument
802.11G has a raw bit rate of 54mbps, however there's a lot of overheads - in fact the figure you're seeing is actually pretty good and near the top of what's theoretically possible for a mixed mode 802.11b/g TCP data connection. See http://www.atheros.com/whitepapers/atheros_range_whitepaper.pdf for the theory behind this.
04-09-2010 11:36 AM
- Full Fibre
