FTTC - Pro account
- Full Fibre
- Re: FTTC - Pro account
FTTC - Pro account
17-11-2010 11:12 AM
Now that FTTC is up and running at gorgeous speeds I did some homework to find out why Iplayer , PSN , peer-2peer etc etc etc aren't getting the full bandwidth and discovered that because Im on a Value package all these services are capped at various levels... you get what you pay for I guess.
My question is: Is there still a Pro package availible to take advantage of the new speeds as I seem to remember that all the services where max'd ( line speed) out that. ?
Message 1 of 6
(1,408 Views)
5 REPLIES 5
17-11-2010 11:24 AM
http://www.plus.net/residential/broadband/pro.shtml
Message 2 of 6
(591 Views)
17-11-2010 11:47 AM
ahhh , I see it now... bit hidden isn't it?
20Mb usage is a bit mean isn't it ? Can you confirm that ALL services are un-capped and 'linespeed' ?
Thanks.
Thanks.
Message 3 of 6
(591 Views)
17-11-2010 12:13 PM
I think you mean 20GB – 20Mb over FTTC would take just over half a second to download. I can indeed confirm though that there are absolutely no restrictions to the speed of any protocols on Pro, although the product is still susceptible to traffic management in unusual cases (such as a significant portion of Plusnet's capacity going offline).
Message 4 of 6
(591 Views)
17-11-2010 1:14 PM
yes , 20GB your quite right. sorry.
I'm guessing I could always add extra usege to the Pro product
Thanks.
Thanks.
Message 5 of 6
(591 Views)
19-11-2010 9:33 PM
indeed, but at £5 per 5GB, its not a cheap way of getting very fast speeds...
Message 6 of 6
(591 Views)
