FTTC Expansion?
- Full Fibre
- FTTC Expansion?
Re: FTTC Expansion?
26-04-2010 10:18 AM
Quote Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 19.4 Mbps and upstream line speed of 7.7 Mbps.
Thats my uncles post code. It gives one number of 19.4mbs.
Quote Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed between 20 to 36.2 Mbps and upstream line speed between 7.7 to 13.9 Mbps.
Thats mine. Theres a 16.2mbs range lol.
Re: FTTC Expansion?
27-04-2010 9:35 AM
@dave - would you mind checking the Openreach list again for Shipley to see if there is any news?
I was under the impression the exchange was going to be enabled in April, but none of the phone numbers I'm trying on the checker are saying that FTTC is available.
James
Re: FTTC Expansion?
27-04-2010 2:58 PM
Re: FTTC Expansion?
27-04-2010 3:10 PM
Quote from: JEB I was under the impression the exchange was going to be enabled in April, but none of the phone numbers I'm trying on the checker are saying that FTTC is available.
Sounds like you're in the same position as me: exchange supposedly ready this month but still no sign of any usable FTTC service. Does the address checker mention anything to do with FTTC? It does for my address, which apparently does mean that FTTC is on its way at least. Once it is properly available the phone number checker will then be updated too.
Re: FTTC Expansion?
27-04-2010 4:07 PM
James
tom:quote
Re: FTTC Expansion?
28-04-2010 2:15 PM
Cheers Ed
Re: FTTC Expansion?
28-04-2010 2:53 PM
JEB - it's on the list now as April onwards, I've updated the 21CN list with FTTC now: http://community.plus.net/21cn-exchange-availability/
Addnan - postcodes can be big areas and can be served by more than 1 cabinet and lots of distribution points (telegraph poles for example). The postcode check won't know which cab you're on so the difference is probably the speed if you served by 1 cab against the other.
Bob_V - thanks, can't remember if I've asked, have you tried it wired and wireless in case that makes a difference?
edgold - not get a date yet, will see if I can do some pushing
Plusnet Technology
Re: FTTC Expansion?
28-04-2010 9:45 PM
anyone know how long after that that things will be live?
also will i need a new router?
also is it like adsl2+ with some kind of horrible dlm software?
i'm currently of the dlm and my speed been consistently good which it wasn't under the dlm thumb
Re: FTTC Expansion?
29-04-2010 12:01 PM
Not thought to try direct. Interesting result.
Wireless Download 14170 Upload 8294
Wired Download 19793 Upload 8439
Wireless connection connected at 54Mbps adjacent to router. Linespeed 32Mbps.
Seems the wireless connection is losing me some bandwidth. Why should this be?
Bob Vaughan
Re: FTTC Expansion?
29-04-2010 12:11 PM
Quote from: bluewhale so i saw the engineers out putting the fibre in for my cabinet, i'm on the new southgate exchange
Ooh, only a few miles from me (Ponders End). Perhaps when they've finished fiddling with your exchange/cabinets they'll take a look at mine…
Re: FTTC Expansion?
30-04-2010 9:48 AM
You will need a new router if the one you have doesn't support PPPoE over a WAN port. We're currently supplying a Thomson 585 with modified firmware to use one of the Ethernet ports as a WAN port.
Bob_V - I've seen a couple like this now, do you have any other wireless devices connected? I've seen one being caused by a wireless print server being connected at the same time and I've seen another where there was interference from another router in the neighbourhood on the same channel and also it could be if the wireless card is connected on wireless B rather than G or connecting at a lower speed than 54Mbps.
Plusnet Technology
Re: FTTC Expansion?
30-04-2010 10:51 AM
Re: FTTC Expansion?
30-04-2010 3:17 PM
Plusnet Technology
Re: FTTC Expansion?
30-04-2010 3:31 PM
I have tried every channel on the router from 1 to 13 with no change to the download speed. I have a wireless printer but that is normally turned off. I have a second laptop but that is normally turned off. My laptop is connected at 54Mbps with a very strong signal. Don't know what else to try other than a 802.11n router.
Regards.
Bob Vaughan
Re: FTTC Expansion?
30-04-2010 5:59 PM
