FTTC - Dramatic speed drop
- Full Fibre
- FTTC - Dramatic speed drop
05-01-2011 9:46 PM
Message 1 of 6
(1,237 Views)
5 REPLIES 5
Re: FTTC - Dramatic speed drop
06-01-2011 4:03 PM
Thanks a horrible ping value you have there, mine's in the teens.
Message 2 of 6
(546 Views)
06-01-2011 5:22 PM
have you ran a speedtest on http://speedtester.bt.com/ to see your profile and sync rate? Report the findings here and I'm sure somebody will help.
Mike
Mike
Message 3 of 6
(546 Views)
06-01-2011 9:14 PM
Thanks for the replies - it seems slightly better today with speedtester.bt.com showing
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
15733 Kbps
0 Kbps 34523 Kbps
Max Achievable Speed
> Download speedachieved during the test was - 15733 Kbps
For your connection, the acceptable range of speedsis 12000-34523 Kbps .
Additional Information:
IP Profile for your line is -34523 Kbps
Upload Speed
5340 Kbps
0 Kbps 10000 Kbps
>Upload speed achieved during the test was - 5340 Kbps
Upstream Rate IP profile on your line is - 10000 Kbps
However, speedtest.net shows somewhat different figures when done two minutes later
Is this normal?
Many thanks
Tim
Download Speed
15733 Kbps
0 Kbps 34523 Kbps
Upload Speed
5340 Kbps
0 Kbps 10000 Kbps
Is this normal?
Many thanks
Tim
Message 4 of 6
(546 Views)
07-01-2011 1:09 PM
Whenever you perform a speedtest or any other kind of test, you should always repeat it 3 or 4 times and take an average.
The difference you've seen in results is not unusual as many factors affect your web connection and just one of them changing can result in a drastic change in throughput.
Paul
Paul
Message 5 of 6
(546 Views)
07-01-2011 4:40 PM
Also, how are you connected to your router? If its wireless, are all your devices N rated or G ? If its the latter, theres your problem. If not, try re-testing a few times in off-peak hours(assuming you didnt already)
Message 6 of 6
(546 Views)
