FTTC 80/20 New Connection Current Line Speed Question
- Full Fibre
- FTTC 80/20 New Connection Current Line Speed Quest...
07-08-2012 1:14 PM
Hi Guys
Was put on the 80/20 trial around Aug 6th and my down/up speeds gradually grew to 71/11 respectively and my Current Line Speed showed the 20 mb as I believe it should.
However, although my down/up speeds have remained high, I notice that my Current Line Speed has been changed back to 40 mb.
Will this be an issue and do you chaps at PN need to get the mallet out to change it back to 20 mb?
Thanks in advance for any advice.
Regards
Paul
Regards
Paul
Message 1 of 3
(1,430 Views)
2 REPLIES 2
Re: FTTC 80/20 New Connection Current Line Speed Question
07-08-2012 2:14 PM
The 40000 profile is now correct for the 80/20 trial, we changed it due to some system updates that caused problems. You shouldn't have any issues whether your profile is on 20000 or 40000.
Message 2 of 3
(413 Views)
07-08-2012 2:16 PM
Thanks Chris. Mystery solved!
Regards
Paul
Regards
Paul
Message 3 of 3
(413 Views)
- Full Fibre
