[FTTC] 80/20 Fibre Trial - Predicted speed vs Actual Speed
- Full Fibre
- Re: [FTTC] 80/20 Fibre Trial - Predicted speed vs ...
07-06-2012 5:25 PM
Hi Guys,
80/20 was activtaed last night on our broadband and was wondering if you guys could answer a few questions for me.
Here is what the Broadband Wholesale Checker says:
Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 55.1Mbps and upstream line speed of 13.2Mbps.
Here is what speedtester.bt.com says:
Download speedachieved during the test was - 44.15 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-46.75 Mbps .
Additional Information:
IP Profile for your line is - 46.75 Mbps
Upload speed achieved during the test was - 6.09Mbps
Plusnet Profile:
Current line speed: 20 Mb - This seems a little odd?
I was always under the impression that the broadband wholsale checker is usually very conservative in the predicted speeds, but that doesn't appear to be the case.
Does 80/20 FTTC have a 10 day training period? I have read conflicting information on this subject. Is it likely my speed will increase the longer it remains connected?
Don't get me wrong the speed is great, just wonering if we are likely to get a bit more out of it.
Many thanks
Michael.
Plusnet Profile:
Many thanks
Michael.
Message 1 of 6
(4,014 Views)
5 REPLIES 5
Re: [FTTC] 80/20 Fibre Trial - Predicted speed vs Actual Speed
11-06-2012 5:34 PM
Hi Michael,
It may well settle after the 10 day training period. The 20000 profile on our side is an unrestricted one and is what we set all 80/20 customers on.
Jojo
Jojo
Message 2 of 6
(764 Views)
12-06-2012 9:12 AM
Hi Jojo,
Here are some of my stats.
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 16395 Kbps, Downstream rate = 46760 Kbps
Path: 0, Upstream rate = 16428 Kbps, Downstream rate = 48511 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 16395 kbps 46760 kbps
Actual Aggregate Tx Power: 6.8 dBm 12.7 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 5.4 29.7 44.9 N/A 14.5 36.4 56.3
Signal Attenuation(dB): 7.2 28.9 43.8 N/A 14.5 36.4 56.3
SNR Margin(dB): 6.0 6.2 6.2 N/A 5.3 5.3 5.4
TX Power(dBm): -4.1 -13.1 6.3 N/A 9.8 7.8 5.1
Michael.
Status: Showtime
Retrain Reason: 2
Michael.
Message 3 of 6
(764 Views)
12-06-2012 9:37 AM
I've seen a bit better downstream sync for very similar attenuation: http://community.plus.net/forum/index.php/topic,102776.msg890330.html#msg890330
Are you aware of the excellent graphing scripts by Bald_Eagle1?
Call me 'w23'
Message 4 of 6
(764 Views)
12-06-2012 10:20 AM
Yeah I have seen the graphing stuff, I just don't currently have any way of running it yet. Our house has Cat6 running through tthe whole house, the modem is patched through to the router into the office. I may wait for my Raspberry Pi and use that for monitoring the modem.
Message 5 of 6
(764 Views)
14-06-2012 3:51 PM
I've been meaning to post about this too.
The BT Wholesale checker predicts that I should get around 65Mb down and 20Mb up, however I'm only getting 32 down, and 11 up since I started the trial around a month ago.
I've tried rebooting all my routers/modems on various occasions, but thats all I get
Seems like the BT page doesn't always give pessimistic estimates.
Jim
Jim
Message 6 of 6
(764 Views)
- Full Fibre
