FTTC - 15 NBG-417N Routers for testing
dave
Fixes: 4
Hi guys,
Zyxel have kindly sent us some NBG-417N routers for testing, if you'd like to give one a trial please reply back and I'll get the sent out (chances are they won't arrive before Christmas).
Dave Tomlinson
Plusnet Technology
40 REPLIES 40
jamescarlin
Re: FTTC - 15 NBG-417N Routers for testing
Hi Dave,
I'll give one of the Zyxel routers a go... Smiley  Will be interesting to compare against how the netgear one is - finding the wireless range a bit weak on the netgear tbh...
Cheers,
James
bluewhale
hi dave,
yep i'll give one of them a go too.
will be interesting to compare them to the netgears.
cheers
pete
knowdice
Hi Dave,
I'm currently using a Zyxel NBG334W which for some reason is being fairly unreliable (occasionally just re-boots) so wouldn't mind trying one.
FYI I'm using it in "bridge" mode to "expose" my public IPs on the LAN side, then use extra firewall/NAT for PCs etc.
Richard
tangey
I'd certainly like to give one a go, I've found  the speedtouch a bit (replaces previously censored word with "POOR") on wireless, and a bit inconsistent in allowing things to connect to it.
umm do you need my plusnet username ?
Regards
Ian
daveplus
Fixes: 10
Dave
I would like to try one please.
Dave
dave
Fixes: 4
Thanks guys, James your router went yesterday the rest are going today. Still plenty more if anyone else to wants to give them a try.
Dave Tomlinson
Plusnet Technology
SlinkyWizard
Hi Dave,
I'll give one a go; having all sorts of problems with the Belkin card in my work laptop connecting to the Netgear at the moment.
Thanks,
James Mayl
OldCoggers
I'd like to try one please. The Netgear N seems to have worse coverage than my old Netgear G.
Cheers
Old Coggers
timsheffield
Hi Dave
If you still have any left I would like to try one to compare with the netgear router
Regards
Tim
Picnic
I'll give one a go, used to like my Zyxel I had on my ADSL line.
iciclethief
Hi Dave,
I'd like to trial one if possible.
I'm having issues with Windows 7 and the Netgear router, it randomly drops the wireless connection and I have to keep manually reestablishing it.
Many thanks,
P.S. my plusnet account is smellycat
bigladuk
Hi Dave,
I'll take one if they are OK with FTTP
Si
slime
I'd be interested in trying one although I am not due to be FTTC installed until 30/12. Plus.net have just sent the Netgear but I'd still like to try this one as well.
Cheers,
Si.
PN username: guntons
bluewhale
wow that was quick delivery, although i would rather have had all my xmas present that seem to stuck somewhere ...
gave a quick try and on my setup seemed to work as well as the netgear, same 26mbs over the wireless link
not tried peer to peer on the lan to see how the max rate goes as i read these aren't great on wireless
