FTCC : Just connected this morning
- Full Fibre
- Re: FTCC : Just connected this morning
15-07-2011 12:35 PM
HI ,
BT have come and gone
i did a speed test ( used a couple of different sites ) and none should major increase , was bouncing around the 7 mark .,., not even into the 10's let alone near 40???
uploads had gone up by about x3 .. so it shows it working.
BT man showed me a text on his phone saying that i had 40mb at the modem .. and then said its more than likley my PC etc and then ran off
is this normal , anything for me to check. tried wireless ,and wired .. still the same , tried windows , mac still the same.
web surfing does feel faster ... but just the speed tests are not showing it ?
does feel low when you pay the extra, but got nothing to prove to yourself that somthing is better
cheers
Matt
cheers
Matt
Message 1 of 8
(3,818 Views)
7 REPLIES 7
Re: Just connected this morning
15-07-2011 12:56 PM
Your speed will likely still be limited by your ADSL profile. Check out this link and post your "Current Line Speed". Also run a BT Speedtester and post up the results of that.
Your profile will uplift automatically in due course, or a friendly Plusnet bod might be able to poke it.
B.
B.
Message 2 of 8
(1,074 Views)
15-07-2011 1:02 PM
from your frist link :
Telephone number:
0140325xxxx
Phone exchange:
HORSHAM CARFAX
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-07-07 15:47:42
Current line speed:
7.15 Mb
cant do the bt test yet , till i figure out my service ID
but cheers , it makes sense now , will give it 24hrs and see what happens
Matt
Telephone number:
0140325xxxx
Phone exchange:
HORSHAM CARFAX
Current line speed:
7.15 Mb
Matt
Message 3 of 8
(1,074 Views)
15-07-2011 2:21 PM
you dont need the service ID, just your phone number.
Message 4 of 8
(1,074 Views)
15-07-2011 3:27 PM
Mine was installed at 7am (first call) took until 5pm for the profile to be changed and it gradually increased thereafter...
You'll be limited by your IP profile, i guess PN take their "days installs" and nudge over the profiles before knocking off.... Patience young padawan, 40meg is coming
Message 5 of 8
(1,074 Views)
18-07-2011 12:59 PM
still only showing 7mb , i assume nothing happens at weekends... will give it another 24 hours , then try and raise a support ticket
Matt
Matt
Message 6 of 8
(1,074 Views)
18-07-2011 1:52 PM
not sure if anyone with power read this , just got a text saying things where completed , and check the link above , it now shows :
so something has changed, assume estimated will update at somepoint
PS, i can see the green BT box from my window
Matt
Quote Telephone number:
0140325xxxx
Phone exchange:
HORSHAM CARFAX
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-07-18 14:50:25
Current line speed:
37 Mb
Matt
Message 7 of 8
(1,074 Views)
18-07-2011 7:39 PM
The estimate is for ADSL. They don't change it when you go to fibre. See this thread.
Message 8 of 8
(1,074 Views)
- Full Fibre
