Entering FTTP Trial from BT
m4tthew
I have FTTP which is currently provided by BT and my contract is coming up for renewal. I am looking at alternative providers and would like to know if I can swap to Plusnet? If I can change and join your trial how would I go about this?
p.s. bt availability checker results are below
3 REPLIES 3
Fixes: 48
Re: Entering FTTP Trial from BT
The PlusNet FTTP Trial is for existing customers only.
Apart from BT as far as I know only Zen Internet and Andrews & Arnold are the only major ISP's to offer FTTP.
RealAleMadrid
Aspiring Hero
Fixes: 59
If you have a normal phone line you can order an ADSL service  from PlusNet then apply to go on the FTTP trial, I know it's crazy but that's the way they do it.
HarryB
Fixes: 256
Welcome to the community forums @m4tthew.
While it's less than ideal, the advice given by @RealAleMadrid is the only way for us to currently get you on the FTTP trial with us, as it's only open to existing customers.
A few questions surrounding how to do this were discussed over on this thread: https://community.plus.net/t5/Fibre-To-The-Premises-trial/Another-BT-FTTP-to-Plusnet-FTTP-trial-swit...
I hope this helps.
 Harry Beesley
