Engineer just left...
brassedoff
The Openreach engineer has just left. I'm currently running at 1.9M down and 8.3M up
...until the IP profile sorts itself out. Dead easy setup using my own equipment (Draytek 2920) into the Huawei VDSL modem.
10 REPLIES 10
adamwalker
Fixes: 221
Re: Engineer just left...
Good news, thanks for the feedback. Please keep us appraised as to how your speeds improve and if you encounter any issues.
 Adam Walker
dave
Fixes: 4
Speed profile updated, you might need to reboot the BT modem and your router for the change to take effect.
Dave Tomlinson
Plusnet Technology
brassedoff
VDSL modem restarted. Job done:
Thanks, chaps!
I'll continue to monitor over the coming days.
paulalexleeds
Do the profiles reset themselves or need to be done manually via a support ticket? My line was upgraded this morning and my profile is still set at 4.5MB.
dave
Fixes: 4
We try and update the profiles in the morning before the appointment but sometimes the engineers are a bit quicker than us. Your profile's now updated so you should now be seeing an increase in speed (you may need to disconnect/reconnect or reboot both the BT modem and the router for the change to take effect).
Dave Tomlinson
Plusnet Technology
LiamRo
Engineer left here, in Rostrevor, about an hour ago.
Currently getting
will keep you all updated
otherdave
Engineer left a couple of hours ago 7.6 M up 1.3 M down  He said it was probably the Netgear router that was the problem as he'd not seen one before. Will wait in anticipation that the profile correction sorts it out.
brassedoff
otherdave, I shouldn't worry - that's exactly what mine did:
http://www.brassedoff.net/wp/?p=942
You can see the upload speed come up followed by the download once the nice Plusnet people reset the profile in response to seeing my post on here.
otherdave
brassedoff, thanks for your reassurance - I  hope  those really nice Plusnet people do the same for me.
Silverscooby
Engineer has just left and I'm getting 0.69 mbit/s down and 7.49 mbit/sec up.
Can I get my profile changed ?
Cheers,
Rob
