Current Line Speed has gone mad
- Full Fibre
- Re: Current Line Speed has gone mad
30-05-2014 11:26 AM
Just checked my current line speed and saw this:
"Estimated line speed:
Current line speed:
300 Mb"
Shame BTW says it is this
"For your connection, the acceptable range of speeds is 40 Mbps-87.77 Mbps ."
George
Current line speed:
300 Mb"
George
Message 1 of 6
(3,140 Views)
5 REPLIES 5
18-06-2014 11:32 AM
Hi George,
Openreach are withdrawing the 100Mbps product so we're going to have to move people on to either 80, 200 or 300Mbps. The default will be to move to 80Mbps but before we can do that we need to fix the 300Mbps profile on the network, we're half way through by changing the portal and internal systems 100Mbps profile to 300Mbps and we're working on the network side now. Then we can start contacting people and see what they want to do. So, apologies for the confusion but it's the simplest way of getting 300Mbps to work.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 6
(686 Views)
08-10-2014 9:26 PM
Checked my current line speed tonight and it now reads 40Mb.
Currently the BTW/TB/speedtest results still show speeds in the 75-78Mbs download range but concerned that if I have a disconnection then I will find my speed throttled down to 40Mb.
Could someone correct the line speed please?
Thank you
George
Thank you
George
Message 3 of 6
(686 Views)
09-10-2014 9:17 AM
Hi George,
I've put it back to what it should be for you. Sorry about that.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 4 of 6
(686 Views)
09-10-2014 10:26 AM
Thank you Dave
Message 5 of 6
(686 Views)
13-10-2014 10:44 AM
Quote from: dave Hi George,
Hi Dave, is there any chance I could trial a 300Mbps profile? thanks Neil
Message 6 of 6
(686 Views)
- Full Fibre
