Bradwell Abbey Testing
dave
Fixes: 4
This post is aimed at those users on Bradwell Abbey with FTTP who still have their ADSL lines active (and hopefully ADSL router still).
BT are trialling some new kit at Bradwell Abbey and want a couple of volunteers so they can makes sure it works. Only testing you'll need to do is make sure you can connect and browse OK on your ADSL line. It won't alter anything on your FTTP service.
If you can help out then that would be appreciated please just post and we'll let you know when the change has been done and if you can then just connect and browse and let us know all is OK that'd be really helpful.
Dave Tomlinson
Plusnet Technology
9 REPLIES 9
PaulStunt
Re: Bradwell Abbey Testing
Hi Dave,
Happy to test this but can you confirm my ADSL line is still active ?
I have an old BT homehub kicking around that I think will work but might take some configuring first.
Cheers
Paul
dave
Fixes: 4
Thanks Paul, appreciated. Will let you know when it's been done.
Dave Tomlinson
Plusnet Technology
dave
Fixes: 4
Hi Paul,
BT have made the change, can you give it a go and see if it works please?
Dave Tomlinson
Plusnet Technology
PaulStunt
Hi Dave,
I have managed to dig out my old BT Homehub and have managed to connect but I have not been able to browse any web pages.
I expect this is because the IP address I was being assigned is the same as my FTTP address, as I have a fixed IP and not dynamic.
Cheers
Paul
dave
Fixes: 4
Ah, I'll send you over a PM with a test username you can use.
Dave Tomlinson
Plusnet Technology
PaulStunt
Hi
Using the test account details that were sent I was able to login and browse with no issues.
Not sure if you needed any further information but just shout if you do.
Cheers
Paul
Chris
Legend
Fixes: 169
Hi Paul,
That's great, thanks for letting us know.
Sbcs37
Hi
If you are still wanting tests done please let me know - just have to plug in the router
Regards
Alan
Chris
Legend
Fixes: 169
Thanks Alan, and to the others who helped out. We're now in the process of working with BT to move all customers on Bradwell Abbey over to the new equipment. We've done about 50% so far with more to go tomorrow and early next week.
