Bit of a rant... Sorry
- Full Fibre
- Re: Bit of a rant... Sorry
16-08-2015 1:37 PM
16-08-2015 2:40 PM
Since then I have bought other routers as I wanted a dual band router and then upgrade to an AC Wifi router.
16-08-2015 4:21 PM
Quote As part of the trial we'll supply you with a free router. Most ADSL routers are not compatible with FTTP. If you want to supply your own router then please let us know but be aware that the router you're using must support PPPoE over an Ethernet/WAN port
I'd get back in contact with them and point this out as they most certainly should have provided you with an FTTP compatible router.
You will still need to use the OpenReach supplied modem, your FTTP compatible router will then connect to this via ethernet the same as I imagine you currently have your work borrowed router connected to it
16-08-2015 4:39 PM
16-08-2015 5:08 PM
16-08-2015 6:08 PM
16-08-2015 6:42 PM
He mentioned the VDSL2 modem, which is for FTTC and not FTTP. Just clarifying whether he's on the FTTP trial.
16-08-2015 8:44 PM
18-08-2015 11:40 AM
I'll get you a router sent out today.
18-08-2015 2:24 PM
