BT installed Huawei modem takes an age to connect
- Full Fibre
- Re: BT installed Huawei modem takes an age to conn...
18-01-2011 11:24 AM
Or is it just me? Sometimes 10 mins after power up. Any way to get in to the settings?
Message 1 of 4
(1,226 Views)
3 REPLIES 3
Re: BT installed Huawei modem takes an age to connect
18-01-2011 12:18 PM
I see a delay of 5 minutes or so after power up.
It has been suggested if you just drop the line then it takes a time for the previous PPPoE session to time-out before a new one can be established - may be Plusnet can comment.
Ideally get your router to disconnect the PPPoE session before power cycling the BT modem.
You don't have any software access whatsoever to the BT VDSL+ modem
Message 2 of 4
(558 Views)
18-01-2011 1:36 PM
I thought that you were meant to leave the BT modem powered up all the time? (According to the BT engineer if we keep switching it off the speed will decrease as the line thinks it has a fault? It'll then take a while for the speeds to ramp up again - he said if we go on holiday and switch it off we will have to accept waiting a couple of days before our full speed will return - is that true?)
We've been leaving the BT modem switched on 24/7 (apart from when the power tripped the other day) but switching the Netgear router off at night. Is there any reason why we should do anything different?
Message 3 of 4
(558 Views)
18-01-2011 1:39 PM
I don't turn mine off at night, but have power cycled from time to time due to other reasons and haven't seen a speed problem.
Message 4 of 4
(558 Views)
- Full Fibre
