BT Modem Reliability
- Full Fibre
- BT Modem Reliability
Re: BT Modem Reliability
21-05-2011 11:06 PM
If I reset the modem and it is still warm it will not connect and the DSL light just flashes or remains off. If I leave it off for about half an hour then switch it back on I get about two minutes of connection, then it dies.
The modem runs 'warm' but not particularly hot and is on a shelf with the router.
Seems to be a crap cheap bit of kit! About time someone bought out an alternative...
Looking forward to getting back up and running soon as using an iPhone is not fun!
George
22-05-2011 10:02 AM
Not sure what BT's policy is on this though...
An iPhone not fun...that's new
22-05-2011 7:31 PM
If only the fridge freezer was near to the modem then I could try shutting it in there to see how long the connection would stay up for!!
BT: this is a very poor piece of kit.
@knowdice- I'm not an apple fan and never will be. Fortunately I dont pay for the iPhone, my employer does!!
George
23-05-2011 9:01 AM
24-05-2011 8:57 AM
24-05-2011 10:24 AM
Time to get modems re-spec'd and issue good ones!
24-05-2011 9:57 PM
I've gone back to ADSL to regain connection (from 20-40mb to 0.5mb!!!), I wonder if the BT terminal is the problem? LED status on it is fine, appears to have solid connection, but nothing being received. I await a response from the techs at Plusnet.
28-05-2011 2:08 PM
28-05-2011 11:02 PM
of course i know what the lkiely answer will be 😞
01-06-2011 2:59 PM
The Openreach engineer completed my FTTC upgrade on the 20th of May. I wall-mounted the modem on the same day. On the morning of the 25th, I power-cycled the modem...and lost sync. I know, I know...what was I thinking?! Everyone knows that you can't expect Huawei fibre modems to withstand such an invasive stress-test.
Anyhoo, I raised a fault with Plus and had to make do with a laptop tethered to my Android phone for 'net access (cue much wailing and gnashing of teeth.) Openreach pitched up again on the morning of the 28th. The engineer watched his handheld sync straight away, rolled his eyes and wandered back to the van for another modem. After swapping the old Huawei door-stop, *cough*, sorry, high-quality modem with a new one, he said that over 90% of his FTTC faults are due to modem failure. He went on to say that BT's management are aware of the problem because one of them spent a day out and about with him and was surprised with the frequency of their failure.
Let's hope they kick Huawei's finest into the tall grass as soon as possible.
02-06-2011 1:04 AM
The galling thing then would be that I would have a much better piece of kit, which is capable of telling me the useful line stats, sitting idle.I'm not sure I'd leave it idle for long
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
02-06-2011 7:54 AM
Strangely I think I'm the only person who uses these forums that just wants a Modem for FTTC rather than a combined modem and router. Simple reason is I've a very capable firewall sitting behind it, and the moment I have to put a router between them, I negate the benefit of the firewall a chunk (And make my networking a tad more complex, double NAT anyone?)
05-06-2011 10:32 AM
05-06-2011 2:44 PM
I'm on the fifth day of my installation and I've only had service for one day and that was the following day; at the moment I'm stuck with a modem that's sync'd but no ethernet frames are being exchanged, no PPPoE negotiation takes place.
Still waiting to hear back from the faults team, currently sharing 3's HSDPA which is working wonderfully - if only the same could be said for FTTC.
05-06-2011 3:00 PM
Prior to my modem going down I had an IP Profile of over 38 meg down and over 8 up :D! This status quo remained until my BT modem decided to hoist up the flag and stop working :'(. This was replaced on May 24th, and ever since then I have an IP profile of 19359kbps down and am getting just over 2meg up. PN quote "It can take a period of solid connectivity to return your connection speeds to normal. We would recommend you maintain connection for a further 48hrs before powering off your Openreach modem and Netgear router and straight back on again. This should cause your speed to improve however please reply to this message if not and we will investigate further". I have reset the modem and router, as requested, and to date no improvement......
What have others experienced with their speeds when their modems have been replaced?
Just in case anyone from PN is looking into this the open question number is #42809480
Regards,
George
