80/20 trial and Apple Time Capsule
- Full Fibre
- Re: 80/20 trial and Apple Time Capsule
22-03-2012 3:57 PM
Can I carry on using my Time Capsule as a PPPoE client during the 80/20 trial?
André
André
Message 1 of 8
(3,273 Views)
7 REPLIES 7
22-03-2012 4:20 PM
There shouldn't be any reason why not.
Message 2 of 8
(849 Views)
27-03-2012 4:34 PM
Well, first impressions are very good.
Getting approximately 65/12 speeds. Seems very reliable and the Time Capsule is managing to establish a PPPoE connection just like before.
So far, then, a big thumbs up
Message 3 of 8
(849 Views)
29-03-2012 10:51 AM
I've just joined the trial and I'm using the Apple Extreme base station with 'n' wireless enabled.
Through the wired ports I'm seeing 66/16 but via the wireless connections I'm getting around 22/16.
I've checked the connection speed of the wireless speed from the iMac and MBP and they both say they are connected at 130Mbps.
Seems odd, and I was wondering if anyone else had seen this?
Thanks, Sean.
Thanks, Sean.
Message 4 of 8
(849 Views)
29-03-2012 10:58 AM
remember that the 130 is both ways without overheads, so 22/16 is probably not too far out.
What did you get before the trial?
Message 5 of 8
(849 Views)
29-03-2012 11:22 AM
I don't think I looked that closely before the trial!
Anyway, the ZyXEL from PlusNet just arrived so I'll give that a blast later and see if it makes any difference.
Interesting though that we are now constricted by the wireless speed and not the broadband anymore!
Message 6 of 8
(849 Views)
29-03-2012 9:28 PM
OK. Results are in.
Speed is now 28/16, so a gain of 6Mbs.
Is it worth it? Not sure.
Message 7 of 8
(849 Views)
10-04-2012 7:01 PM
Wireless Ethernet is the work of the devil. I've got Cat6 all over my house. Anything that's bandwidth intensive get's done over Gigabit ethernet
Message 8 of 8
(849 Views)
- Full Fibre
