80/20 Trial - First day and 2nd Day - Very impressed with Speeds and Zyxel
kevhky
This is my first day of the trial and im using a Bipac 7800n router
Upload speed seems fine but the download needs to be higher me thinks, time will tell
This reeading was from a wired connection
Kev
12 REPLIES 12
Chris
Legend
Fixes: 169
Re: [FTTC] 80/20 Trial - First day
Looking at your line profile, the throughput is pretty close to what can be expected. Your line currently has a profile of 58.9Mb so I don't think you'll see much higher download speeds.
kevhky
Second Day - Very Impressed
http://speedtest.net/result/1861624251.png
Well ive just connected the Zyxel and the speeds are pretty much the same as earlier (wifi connection)
Zyxel was very easy to setup and ive found the wifi signal is excellant around the home, pc upstairs connted to it is showing 300mb and a speed test carried out upstairs conneced via wifi was excellant same as the wired connection above
Overall very impressed with the Zyxel shame i cant get the full 80mb but who would complain as few weeks back i was getting 8mb via adsl
Kev
w23
Fixes: 4
Re: 80/20 Trial - First day and 2nd Day - Very impressed with Speeds and Zyxel
Any idea how far you are from your cabinet?
Your speeds are very similar to mine and I'd be interested to know if you are similar distance.
Call me 'w23'
kevhky
Quote from: walker23
The cabinet is at the top of my road id say approx 1/4 of a mile to 1/2 a mile
Kev
w23
Fixes: 4
Thanks,
I recon I'm a bit less than 1/4 mile but I'd need to try to measure it a bit more accurately.
Call me 'w23'
kevhky
Is there not anywhere that could give us that information, mune probably is closer than i said.,
Kev
Ronski
You can use Google to calculate the route by road or walkjogrun.net to trace a route to your cabinet, of course this means a bit of guess work as to what route your line takes.
kevhky
My speeds increasing im upto 63mb download this morning
Kev
siddalr
Distance to cabinet as crow flies: 550yds
FTTC Stats before 80/20 Trial
IP Profile: 38.72Mbps  (as reported by speedtester.bt.com)
Downstream throughput: Typically 31 to 34Mbps
Upstream throughput: ~8Mbps
FTTC Stats during 80/20 Trial
IP Profile: 40.63Mbps  (as reported by speedtester.bt.com)
Downstream throughput: Typically 31 to 37Mbps
Upstream throughput: Typically 8.3 to 9.7 Mbps
evans356
i can't get that speedtester.bt.com to work, i enter my phone number and it does nothing
Sad
w23
Fixes: 4
@evans356, if you just want to get your BT line profile then you could try this: http://windows.mouselike.org/be/index.asp?DoAction=BrasChecker
Call me 'w23'
siddalr
    View Profile
« Reply #10 on 03/04/2012, 15:38 »
> "i can't get that speedtester.bt.com to work..."
You are not alone.  I have had problems with BT's speedtester recently too.
