what happens when u get fibre
St3
Aspiring Champion
Fixes: 5
Will I get new connection details or do I use the ones I have for adsl eg username and whatnot
Re: what happens when u get fibre
I got a new router though to post from Plusnet and the OR engineer brought an OR modem with him.
The Plusnet router has the logon details embedded so it's just plug and play. If you want to use your own router you will have to input the username and password manually  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
St3
Aspiring Champion
Fixes: 5
as its the first time for me getting fibre, do I use the current connection settings I have with adsl to enable fibre to work on my router ?
Fixes: 247
yes, your username and password remain the same.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
But you will not be able to use your old ADSL router Smiley
St3
Aspiring Champion
Fixes: 5
yep cool cheers peeps Wink
