what happens when u get fibre
- Re: what happens when u get fibre
16-11-2014 11:36 AM
Will I get new connection details or do I use the ones I have for adsl eg username and whatnot
Message 1 of 6
(958 Views)
5 REPLIES 5
16-11-2014 3:23 PM
I got a new router though to post from Plusnet and the OR engineer brought an OR modem with him.
The Plusnet router has the logon details embedded so it's just plug and play. If you want to use your own router you will have to input the username and password manually
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 2 of 6
(477 Views)
17-11-2014 10:44 AM
as its the first time for me getting fibre, do I use the current connection settings I have with adsl to enable fibre to work on my router ?
Message 3 of 6
(477 Views)
17-11-2014 10:58 AM
yes, your username and password remain the same.
Message 4 of 6
(478 Views)
17-11-2014 11:02 AM
But you will not be able to use your old ADSL router
Message 5 of 6
(478 Views)
17-11-2014 2:22 PM
yep cool cheers peeps
Message 6 of 6
(478 Views)
