weird speed results
Smeaghoul
weird speed results
just got connected to fibre
on 80Mb account
router reports 41mb d/l  &  19.53 u/l
speedtest 2.82mb d/l  18.75mb u/l
upload speed about right but what's with the download speed, it's about  ???what I was getting on adsl connection
10 REPLIES 10
MatthewWheeler
Fixes: 479
Re: weird speed results
Can you test it in the next 15 minutes?
 Matthew Wheeler
Smeaghoul
now getting 39.03 d/l    18.70 u/l
better but still pretty low, only 50m from cabinet should be getting 70+mb
HarryB
Fixes: 256
Looks like your connection is in sync at 42Mbps down and 20Mbps up.
Testing the line has also come back with the following result:
Voice fault suspected - contact Voice CP to progress copper issue
We'd need you to contact your phone provider to investigate the line fault. When contacting the phone provider it's best to not mention broadband as they may send you back to us, despite the test advising the phone provider to raise the matter.
 Harry Beesley
Smeaghoul
I'll look into it, thanks
Smeaghoul
Been in touch with BT, difficult as it turns out I actually have no phone service (problem with the line), they're sending an engineer on 01/04, too much of a coincidence to think that it's anything else but a wiring problem at the cabinet, after all there were only three engineers there doing the work Smiley
HarryB
Fixes: 256
Hopefully your speed bounces back shortly after that's fixed, but if not please do let us know so we can look in to it further
 Harry Beesley
Smeaghoul
Just had Bt engineer on the phone fault fixed, router showing 78Mb d/l, speedtest still showing 39Mb, can someone give it a nudge, thanx
MatthewWheeler
Fixes: 479
 Matthew Wheeler
Smeaghoul
OK 73.5 d/l 18.7 u/l , sorted thank you so much, ps. it was a broken wire at the cabinet
HarryB
Fixes: 256
Glad to hear it's sorted Smiley
 Harry Beesley
