weird drop just happened
- weird drop just happened
10-08-2016 3:38 PM
I've just witnessed the most weirdest of drops ever, i was watching Sky on the PS4 and it started buffering so logged in to the HH5 to see i was still connected. Done a gateway hop, upon pressing disconnect it was fine then went to connect and it took a long time. Checked my DSL uptime that's been reset also and now my traceroutes have changed all of a sudden.... below is my traceroute to bbc
Tracing route to bbc.co.uk [212.58.244.22]
over a maximum of 30 hops:
1 6 ms 1 ms 1 ms bthub.home [192.168.1.254]
2 10 ms 10 ms 9 ms l0.default.pcl-bng02.plus.net [195.166.130.150]
3 10 ms 9 ms 9 ms 409.te8-8.pcl-gw01.plus.net [84.93.248.136]
4 10 ms 10 ms 11 ms lts4.bt622-14.plus.net [212.159.2.68]
5 11 ms 10 ms 10 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 10 ms 9 ms 9 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 * * * Request timed out.
9 16 ms 9 ms 9 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 19 ms 11 ms 10 ms 132.185.255.148
11 16 ms 9 ms 10 ms 212.58.244.22
New network?
If you Like it, give it a
Re: weird drop just happened
10-08-2016 3:47 PM
Doesn't look like the new network as there are no hops with irnn in them. (nn being 01,02 etc)
10-08-2016 3:50 PM - edited 10-08-2016 3:56 PM
I wonder where this route has come from then also i'm on a static IP? i might try a hop soon see if anything changes
10-08-2016 3:57 PM
Pretty similar here
C:\Users\ian>tracert bbc.co.uk
1 2 ms 1 ms 1 ms PNHUB1 [192.168.1.254]
2 9 ms 9 ms 9 ms lo0.12.central12.ptn-bng01.plus.net [195.166.128.230]
3 12 ms 10 ms 10 ms irb.12.ptw-cr02.plus.net [84.93.249.34]
4 10 ms 9 ms 9 ms ae2.ptw-cr01.plus.net [195.166.129.4]
5 11 ms 9 ms 9 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
6 * * * Request timed out.
8 11 ms 10 ms 10 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
9 11 ms 10 ms 10 ms 132.185.255.148
10 10 ms 9 ms 9 ms 212.58.244.22
Trace complete.
C:\Users\ian>
11-08-2016 9:54 AM
Loads of weird drops last night:
It's definitely not to do with the new network. Are you ok to update the thread if this happens again?
Matty
11-08-2016 11:48 AM - edited 11-08-2016 11:49 AM
@MattyC yeah i'll update if anything happens again. That radius graph looks fairly weird to me? I've not had a drop since 3:45pm ish yesterday.
5. | VDSL uptime: | 0 days, 20:20:24 |
Connection time: |
That's just taken from my router.
11-08-2016 3:05 PM
The first bunch of dropouts could have been automatic attempts at authenticating, though I can't really vouch for later on!
11-08-2016 4:06 PM
I'll keep an eye on it. 🙂
