web safe filtering
bustermissy1961
web safe filtering
as the title says does plusnet enable any sort of web safe filtering by default if so how do you disable it.
MattyC
Champion
Fixes: 46
Re: web safe filtering
There shouldn't be unless switched on at sign up. What does this page say for you?
bustermissy1961
thanks it wasn't on.
MattyC
Champion
Fixes: 46
Thanks for clarifying. There shouldn't be any filtering in that case.
Matty
Casey
I think PNet have to abide by UK court orders - so torrent sites and TehParadox, for example, will be blocked. *cough* TOR browser * cough*
Fixes: 127
Afaik they haven't been mentioned in any court orders, but as a result of using the bt network blocking occurs anyway.
Will Moderate For Thanks
Casey
Yes... Grrrr.. I like TehParadox - not for anything shady but it's a nice forum community for helpdesk and off topic. Tor works but it's a little slow and you sometimes need to "New Identity". So.. TP is accessible direct with PNet then? Can you try it for me: http://tehparadox.com/
bustermissy1961
Access to the websites listed on this page has been blocked pursuant to orders of the high court.
More information can be found at www.ukispcourtorders.co.uk
Casey
So PNet has to block them via the court order too.. If I remember the story when it came out, there's only one UK ISP that refused to block them, forgot the name though, dunno if it's still going. Tor still works though, hopefully TOR will work on PNet too. Money buys judges..
