video buffering and lag spike in game
sebjo
hello
i was wondering if someone could check the priorities on my line , i have massive lag spike in league of legend ( from 39ms to sometimes 1600+ms )and sometimes on other games and most of the video i watch ( stream , youtube ,... ) seems to buffer slowly , and my fibre is around 76Mb
thank you
rongtw
Fixes: 11
Re: video buffering and lag spike in game
The first Question you will be asked here , are Wired or WIFI ?
sebjo
wired , using a home hub for better wifi
sebjo
6 days and not an answer from plusnet , way to make customer proud guys !!!
rongtw
Fixes: 11
Currently showing as 8 staff logged in ,,,  another post that has slipped though Sad
How are you testing ? have you set up a TTB graph http://www.thinkbroadband.com/ping/monitors.html
you should be able to check how your connection is , like mine below
sebjo
i use the bt homehub which is not supported by that TTB
rongtw
Fixes: 11
@Anoush  can you help ?
sebjo
so much pride in their customer service ,i can't even watch a stream on netflix without buffering in the evening ,i never had that when i was with bt or talk talk , such a shame , guess i'll go back to bt
