upgrading from Plusnet Broadband to Fibre Extra, but speed doesn't change
- upgrading from Plusnet Broadband to Fibre Extra, b...
24-04-2020 6:33 PM
Dear community members,
A month ago I upgraded my internet from Broadband (10Mb/s speed) to Fibre Extra (66Mb/s). Received and installed the new Plus Net One Hub three days ago. The Speedtest.net results are still the same as before (15 Mb/s download, 1 Mb/s upload). Do I need to activate anything to take advantage of Fibre Extra's greater speeds?
With the best of wishes,
Questioner
Re: upgrading from Plusnet Broadband to Fibre Extra, but speed doesn't change
25-04-2020 1:28 PM
Have you had any updates yet Questioiner?
Equally waiting a long time for a response from support. All the support telephone lines appear to be closed but they're still available for new sales it seems =/..
25-04-2020 3:05 PM
@Questioiner it doeant sound like the upgrade to fibre has happened yet.
Can you post the results of the troubleshooting>helpdesk display on the hub one
Also look at the bt wholesale checker here https://www.broadbandchecker.btwholesale.com/#/ADSL for your phone number, check the narrative under the speed estimates for something like
' there is an open order on your line , due to complete ...'
If there is , that's likely when the upgrade will actually happen
