upgrade router
- upgrade router
upgrade router
29-09-2016 9:09 PM
I've got the technicolour modem still, is it worth it to get the latest plusnet hub?
Re: upgrade router
30-09-2016 3:10 AM
Key benefit of Hub One over TG582n are:
1. Single unit can replace both Openreach modem and router.
2. Offers 5 GHz wifi, if you have devices which can use it.
3. Gigabit ethernet LAN ports.
The Hub One is a rebadged BT Home Hub 5 type A. There is also a rarer Home Hub 5 type B variant which is perceived to be better.
Hub One can be obtained for no more than the cost of delivery if you are out of contract and decide to re-contract with Plusnet.
Re: upgrade router
30-09-2016 8:23 AM
@bill888 is correct with those points!
Again the convenience of just being able to have one unit and one power socket needed is the main benefit.
James
Re: upgrade router
30-09-2016 8:47 AM
What problems are you experiencing with the TG582 that make you think you need to replace it?
Re: upgrade router
30-09-2016 1:59 PM
getting dead / slow wifi spots in the house, how much is it if you're in contact (well renewed when moved)?
Re: upgrade router
30-09-2016 2:05 PM
If you've renewed your contract within the past 3 months they'll only charge the p&p (£6.99)
Re: upgrade router
30-09-2016 2:57 PM
thanks for the info, I might give them a call...I like the hold music
