unstable fibre speed
smilers63
I have been having problems with my broadband speed and reliabilty for several hours now . BTW is showing 11Mbs down and .2 Mbs up (whats going on).
20 REPLIES 20
adamwalker
Fixes: 221
Re: unstable fibre speed
Hello there,
Line tests that I've just been running do pick up on a fault. I can see you started raising one online so the best thing to do is go back to http://faults.plus.net and complete the steps on the troubleshooter.
Let us know when you have and we'll push that forward.
 Adam Walker
smilers63
Hi
I completed troubleshooter and have replaced my Mk 2 masterbox with model 5c using Mk4 face plate but still have same issues.
smilers63
Hi
Connected by ethernet direct to router
BTW test  19.0Mbps down, 0.38 up  68 ms ping
current line speed ( plusnet ) 32 Mb
adamwalker
Fixes: 221
OK, thanks a lot for trying out what you can. I just popped on to your account and can see someone has picked up on your fault and is looking into it now so you should see a more detailed reply to the ticket soon.
 Adam Walker
smilers63
I have made the following observations and deem it unlikely to be a fault on my side, the slow downs and drops are when it is raining outdoors  and when the weather has been dry for over a hour or two the speed and sync go back to normal.
smilers63
Well the engineer visited yesterday (excellent chap, very knowledgable and professional.) tested equipment and wireing, found a fault on the pole (blue beeds).
System seems to be operating ok now, although I will monitor for another 72 hours to be sure.
Chris
Legend
Fixes: 169
That sounds positive, thanks for letting us know. If you can reply when you've had chance to monitor this and confirm it's resolved that would be great.
smilers63
Unfortunately the speed has  dropped again, by over a third and yes its raining again. Please see results in attached file.
smilers63
This is the report back from CSC.((What does this mean?,(will my fault be persued ?))
0.128M-55M Downstream 6dB, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Sync Status In Sync
Downstream Speed 38.2 Mbps
Upstream Speed 6.0 Mbps
Description Downstream ES and SES have exceeded threshold from real time check. Continue submitting trouble report
Start Time Stamp 2017-10-03T16:47:18.716+01:00 2017-10-03T17:02:18.716+01:00
Ingress Code Violation 0 373
Egress Code Violation 0 8
Errored Seconds 405 183
Severely Errored Seconds 0 0
Unavailable Seconds 0
0
smilers63
Hello
today the weather is dry and sunny. The broadband speed is now 32Mbs down (a drop of 7Mbs). and 1.1 Up (a drop of 4.9Mbs)....
A reply would be nice!!!!
MatthewWheeler
Fixes: 480
Sorry for the delayed response.
Essentially your line has a high amount of errors which points towards there still being a fault.
I'll update your ticket shortly.
 Matthew Wheeler
smilers63
Hello  all.
  My speed is now 20Mbs down and 0.3 Up.
smilers63
Hi
The line appears to be degrading day by day as the latest BTW test showsBTWresults0710171156dry.png
smilers63
My router inf is showing some unusual settings, the upstream an downstream output power (dBm) are now minus numbers. eg -4.1. also the
      and the  Downstream noise safety coefficient (dB): has risen from 6.1 to 10.ROUTER INF0710171226.png
