ah
SpendLessTime
Aspiring Hero
Fixes: 82
Re: How do I change router password?
There is a guide at https://www.plus.net/help/broadband/router-user-guides/  just click on the picture of your router and follow the instructions in the section "How do I check or chnage my WiFi settings"
ah
Thanks.  I had found a way in the Advanced Settings and went back here straight away to cancel my post but was unable to.
Fixes: 10
Rather than delete your post and topic title and leave us all wondering what it was about you'd have done better to apply strikeout to the whole post and add comment that is was sorted.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ah
OK.  Actually I am glad I erased my post because it induced you to reply and show your long post under your sig that seems interesting and that I am going to read as soon as I have a bit of time.
Fixes: 80
Do you still require help and support @ah?
 Jono H
 Plusnet Community Manager
ah
No, I don't.  Thank you JonoH for asking.
Browni
Aspiring Hero
Fixes: 47
@ah there is one noticeable omission from @jelv's sig - how much he now pays for broadband Grin
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
ah
Easy to find just by checking the website
