unlimited fibre extra speed not increased
simeskyline75
hi, after upgrading to fibre extra a few months ago my speeds are the same as i was getting before the upgrade.
i was wondering if i have been switched over correctly?
i am usually around the 36mbps but feel i should be high 40s low 50s ish
could someone check this for me please
regards
simon
18 REPLIES 18
idonno
Champion
Fixes: 6
Re: unlimited fibre extra speed not increased
What does it say here? If you were getting only 36Mb before the upgrade I doubt if you will see a speed increase i.e. on a 40Mb connection I'd expect to be very near to 40Mb. Upgrading to fibre extra doesn't magically give you a line that will give you more than it is actually capable of delivering. But do check the link. It will reveal all. .
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
simeskyline75
hi,
Terranova667
Fixes: 5
Observed speed for the 1st of April shows 39.9 which the max for Fibre Unlimited so it looks like the switch to Extra didn't happen, one for Plusnet staff to look into.
simeskyline75
yeah, thats what what i was thinking, hopefully a staff member sees this thread
thanks
simeskyline75
any staff about to check?
simeskyline75
its been like this nearly 8 months now, and have been a customer for over 10 years
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Good news and bad.
I've placed an order to move you to 80/20.
Your current snyc rate is 40Mbit but you were actually provisioned on 55/10.
A new order has been placed and should complete tomorrow. Please check back on your sync rate and let us know if you have further problems. If you are still syncing at 40Mbit, we'll probably need to raise this, but it won't be looked at quickly as we're prioritising those without connections at the moment.
 Tony T
simeskyline75
thank you plusnettony, much appreciated
to check sync rate is that just a speed test?
thanks
MatthewWheeler
Fixes: 479
Thanks for getting back to us @simeskyline75
You can find your exact sync rate by logging into your router here and then clicking on the 'Helpdesk' section
Alternatively you can carry out a speed test which will give you a rough idea of if your speeds have improved
 Matthew Wheeler
simeskyline75
hi, i will have to do a speed test as i dont have the plusnet router anymore
any specific speed test plusnet recommends?
RealAleMadrid
Aspiring Hero
Fixes: 59
@simeskyline75  A speed test is not the correct way to check your actual connection speed. There are many factors that can affect broadband speed tests, they all seem to give different results! The router that you are using will be able to show you the sync speed. You just need to know how to log into it and find the required information. How about reading the manual or searching online for the correct instructions. If you say what router it is someone on the forum will be able to help.😁
simeskyline75
Hi, my router is an Asus RT-ac87u
simeskyline75
hi, i have done a few speed tests today, no change in speed as of yet.
i will have a look for the plusnet router today to find the actual sync speed.
simeskyline75
hi, i have done a few speed tests today, still no change in speed as of yet.
could someone up my sync rate please?
