unhappy
- unhappy
unhappy
29-08-2018 7:59 PM
plusnet have told me that it is my responcabbilty to replace the filter that is intigrated in to the openreach socket
can someone confirm when openreach implimented this as all the engineers that have visited my home
have said the whole socket is their responsabilty ???????
thanks for any advise on this
Re: unhappy
29-08-2018 8:22 PM
Responsibility
You only have responsibility for any filters fitted downstream of the BT Master Socket, or plugged into the socket.
https://www.bing.com/images/search?q=openreach+master+sockets&FORM=HDRSC2
Latest versions have 2 sockets with integrated filter, 1 for phone & 1 for ADSL (unfiltered) .
Re: unhappy
29-08-2018 8:39 PM
This is the kind of thing that you can never find any definitive and authoritative statement about. I thought that Openreach's responsibility is up to the test socket, and the filtered faceplate is not really part of the master socket, it can be easily removed to test from the test socket. The filtered faceplate is plugged into the test socket.
Re: unhappy
29-08-2018 8:40 PM
hi gel
thank for your reply this was something i tried to get the tech department of plusnet
they seem to think it includes the filter unit in the socket
i think the tech department need aa little bit more training on this
thanks once again
alan
Re: unhappy
29-08-2018 8:45 PM
hi
if the intigrated filter was not the responcabilty of open reach why do they supply it when fitting the box
three openreach engineers have said that the whole socket is their responsbilty
will email openreach tomorrow to have this confirmed
Re: unhappy
29-08-2018 8:56 PM
A centralised filter on the master socket gives the best chance of you getting the fastest and most reliable connection. That's why they supply one.
These days Openreach don't generally visit when setting up FTTC broadband. So you might only get a modern master socket and filtered faceplate if Openreach were visiting to fix a fault. No Openreach engineer visiting us in the past ever fitted a vaguely modern master socket, and that was when our master socket was so old it was the type that didn't even have a test socket (although that pre-dates the current master socket type, now they always replace an old socket with the NTE5C).
Re: unhappy
29-08-2018 10:23 PM
Re: unhappy
30-08-2018 1:03 AM
the master socket is the property of bt openreach and should be maintained by them
have contact openreach will post reply once recieved
Re: unhappy
30-08-2018 9:30 AM
The demarcation point is the test socket.
Anything inwards is your responsibility, but from and including the test socket outwards is the responsibility of our suppliers.
Arranging an engineer to replace your faceplate would ultimately likely be a chargeable appointment, however it entirely depends on how the engineer signs the job off.
Re: unhappy
30-08-2018 10:05 AM
Have you checked whether you have a faulty filtered faceplate by removing it and plugging the microfilter that came with your router into the test socket?
If it is faulty then replacements are cheap enough, just make sure you get the correct one. They either clip on or are retained by two screws. They are not interchangeable.
Re: unhappy
30-08-2018 6:58 PM
hi all
have spoken to a supervisor about this issue
am using the a filter so for now going to leave it for now
i have contacted BT openreach for them to clarify this once they reply will post the results
