tp-Link W8591ND
- Re: tp-Link W8591ND
tp-Link W8591ND
18-07-2015 11:54 AM
Can I use a TP Link router W8591ND with fibre. If so what settings do I have to configure?
Message 1 of 2
(503 Views)
1 REPLY 1
Re: tp-Link W8591ND
18-07-2015 12:03 PM
I'm afraid not :(. The W8591 is a combined ADSL modem/router, for Fibre you need either, what's usually called, a 'cable' router connected to the supplied BT modem, or a combined VDSL modem router. Some ADSL modem/routers have the ability to convert one of their LAN ports into a WAN port ( and thus replicate a cable router ) but looking at the manual the W8591 isn't one of them I'm afraid.
Message 2 of 2
(319 Views)
