this connection is even worse than vodafone!
dansaxton
plagued with intermittent 700+ ping and <10mbps downloads throughout today - none of which i can seem to capture on the btspeedtester!
what's going on?
Andrue
Re: this connection is even worse than vodafone!
Wired or wireless?
rongtw
Fixes: 12
Dont forget PHONE now Andrue
dansaxton
wired - restarted router (twice) no change - tried on 2 (wired) PCs - both the same
Fixes: 36
Which Gateway are you connected to? Have a look here
You may also have a look at the Broadband Trouble-shooter which will help give more information to try and help you.
dansaxton
You are currently connected to gateway psb-ir01.
This is located in Southbank Point of Presence
I think i went through all the troubleshooter already - everything was ok.
Fixes: 167
I can see you started the faults checker, can you finish going through it at https://faults.plus.net and we'll get the line tested etc.
 Chris Parr
 Plusnet Staff
dansaxton
i did that - apparently nothing wrong with the line
Fixes: 167
The faults checker hasn't been completed yet. If you finish it we can get this looked at further.
 Chris Parr
 Plusnet Staff
dansaxton
fault checker now completed - showed download speed of 8mbps!
This is when i'm connected to the master socket and to the router via ethernet.
