sync speed
FIXED- Subscribe to RSS Feed
- sync speed
26-08-2018 1:34 PM
hiya
can anyone tell me what my sync speed is im synced at please
im trying to get my sync speed backup by trying to leave it connected as longer as i can...
cheers
Fixed! Go to the fix.
Re: sync speed
26-08-2018 2:02 PM - edited 26-08-2018 2:03 PM
If you log in to your router by typing 192.168.1.254 into the address field of a browser you will log into the router administration pages where you will find this information, depending on the router probably on the status page. It will not affect your connection in any way to look at it here.
Re: sync speed
26-08-2018 5:04 PM
Or you could try this transfer speed which gives you your Current line speed. If you are not logged in it will ask you to do so.
Re: sync speed
26-08-2018 5:21 PM
done that but i cant look at my sync speed i have a d-200 netgear modem with a linksys 1900acs so i cant look at my sync speed.. and i cant even access the modem because it blocks access when u put it into modem mode..
27-08-2018 10:44 AM - edited 27-08-2018 10:44 AM
Hi @tibs01
Here's a copy of our test results for your line:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU00000000 |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.3 Mbps | ||||
Upstream Speed | 19.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 537.2 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-08-23T10:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 77.6 Mbps | 79.9 Mbps | 79.2 Mbps |
Up Stream Line Rate | 18.8 Mbps | 19.2 Mbps | 19.1 Mbps |
Up Time | 627.0 Sec | 900.0 Sec | 898.5 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-27T09:24:05Z | 2018-08-27T09:39:05Z |
Ingress Code Violation | 9 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
No issues from what I can see.
Re: sync speed
27-08-2018 12:53 PM
thanks mate seems the speed is goin back up ill keep it on hopefully it will creep back up to 78 and 20
Re: sync speed
27-08-2018 1:00 PM
Re: sync speed
28-08-2018 10:46 AM - edited 28-08-2018 10:48 AM
That transfer speed test does not give the correct result. I am currently on a sync of 59, max 70, but the transfer speed link gives 78. That might be because I have only just transferred and the systems haven't updated themselves yet.
Re: sync speed
28-08-2018 10:52 AM
It looks like your the speed profile on your account was changed by an adviser on the 14th August.
Testing your line is showing your sync rate at 79.9mbps so the profile is currently correct.
Re: sync speed
28-08-2018 11:11 AM - edited 28-08-2018 11:25 AM
whoops - sorry, I think you were responding to OP and not to me?
I still don't see why https://www.plus.net/my.html?action=data_transfer_speed i reporting 78
Interesting: thank you for testing.
Why does my hub (BT Home Hub 6) report
Re: sync speed
28-08-2018 11:55 AM
@sjptd yep you're right, sorry. My response was aimed at you while looking into the OPs account. I bigger glasses.
I've updated your speed profile now but it shouldn't make a difference at all due to the way connections without static IPs are routed across our network.
Re: sync speed
28-08-2018 12:22 PM
@Gandalf Thank you. I didn't really think it would make much difference, but just wanted to check that things were working as I understood them. I see the https://www.plus.net/my.html?action=data_transfer_speed page now reports as expected, and I'll hope for higher speed/lower margin over the next few days as DLM settles.
Re: sync speed
28-08-2018 12:51 PM
Re: sync speed
08-09-2018 1:38 PM - edited 08-09-2018 1:41 PM
Something (presumably DLM) did indeed kick in after a few days as expected/hoped, and we are back on the same speeds as we had on BT before the switch.
The information at https://www.plus.net/my.html?action=data_transfer_speed is wrong again. I've had a data rate of 77.98 Mbps for over three days, and it is reporting 65.8. Not worried, but that page does seem to be very unreliable.
