strange fibre broadband issue
pistolpete33
i installed a bt home hub 5A to use as an all in one for my fibre but for some strange reason it has halved my down speed.
DSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:18:15
Downstream: 78.03 Mbps
Upstream: 19.53 Mbps
on speedtest it is coming back with these results
any ideas anyone?
SpendLessTime
Aspiring Hero
Fixes: 67
Re: strange fibre broadband issue
What does the speed test at BTW show and what IP profile does it show?
Also what speed does Plusnet show here ? You will need to log in to get the Plusnet speed.
pistolpete33
Phone exchange:AYREstimated line speed:80Mb (This may vary between 68.2Mb and 80Mb) - Checked on 2016-04-27 20:37:07Current line speed:78 Mb
thats my plusnet speed
pistolpete33
its asking me to change my user name on the router to do the btw performance test to speedtest@speedtest_domain is this a must?
SpendLessTime
Aspiring Hero
Fixes: 67
Well the Ookla speed test could be wrong. Sometimes the servers they use can go slow.
I always try multiple speed test services when one is slower than expected.
Hence the BTW speed test (which is the one Plusnet recognise) and ThinkBroadband too. Just to see if it is the line or the server at fault.
SpendLessTime
Aspiring Hero
Fixes: 67
No just put in your telephone number  and click on the "Run Diagnostics Test" button
edit: to clarify text
pistolpete33
1. Best Effort Test: -provides background information.
  Download Speed
  69.93 Mbps
0 Mbps 77.35 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 69.93 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.35 Mbps .
 Additional Information:
 IP Profile for your line is - 77.35 Mbps
  Upload Speed
  2.8 Mbps
0 Mbps 20 Mbps
pistolpete33
i changed it because it wouldnt let me do it without
SpendLessTime
Aspiring Hero
Fixes: 67
Well the download speed is the right area.
The BTW upload speed is wrong BUT that is a feature of BTW as it shows mine wrong consistently too. All the other
services show the correct upload speed. This has been happening since 29 February 2016.
SpendLessTime
Aspiring Hero
Fixes: 67
So it all looks good, just Ookla playing up. Smiley
pistolpete33
i just dont understand why i am only getting half the speed to my pc and when i do a speedtest on my phone
pistolpete33
and its not just ookla thats doing it
pistolpete33
SpendLessTime
Aspiring Hero
Fixes: 67
Well I've no idea. Never heard of speedcheckerapi.com, although I note that is registered in Holland sp does it use Ookla servers too.
The BTW one shows good, what doe sthe UK based ThinkBroadBand show?
If it doesn't agree with the BTW one, and all tests are being done via cable to the router, then might want to log a fault
pistolpete33
