still getting really low speed
- Re: still getting really low speed
06-10-2017 5:05 PM
im still getting really low speed meant to be getting 70 package but lowest i got was between 50-60 but not even getting that getting about 20 30 its new line gone 14 days so i cant cancel so im trapped with rubbish speeds -_-
07-10-2017 3:11 PM - edited 07-10-2017 3:12 PM
Your line will typically support up to 40.0Mbps download (Min. 26.3Mbps and Max. 55.0Mbps), 7.6Mbps upload
Plus don't get that upload as well
on 09-10-2017 10:43 AM - last edited on 09-10-2017 11:45 AM by Mav
this no reply stuff is really getting boring now [-Censored-] plusnet
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
09-10-2017 1:14 PM
Weekends the staff are very thin on the ground and unfortunately its getting worse Yes it used to be a LOT better
@Gandalf may come soon
10-10-2017 1:17 PM
12-10-2017 11:52 AM
Just got told nothing can be done -_-
14-10-2017 4:37 PM
Apologies for the delayed response
Your speed is within the estimated speed range/expectations of your line. If your speed or estimates were higher previously, it's possibly the problem is caused by cross talk which is basically other connections being added to the cabinet.
