still getting really low speed
sub91
im still getting really low speed meant to be getting 70 package but lowest i got was between 50-60 but not even getting that getting about 20 30 its new line gone 14 days so i cant cancel so im trapped with rubbish speeds -_-
6 REPLIES 6
sub91
Re: still getting really low speed
Well the speed recommend has changed now to this so before I signed up got told it be between 60 to 70 😡
Your line will typically support up to 40.0Mbps download (Min. 26.3Mbps and Max. 55.0Mbps), 7.6Mbps upload
Plus don't get that upload as well
sub91
this no reply stuff is really getting boring now [-Censored-] plusnet
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
rongtw
Fixes: 12
Weekends the staff are very thin on the ground Sad and unfortunately its getting worse Yes it used to be a LOT better Knuppel
@Gandalf  may come soon Thumbs_Up
MatthewWheeler
Fixes: 479
Sorry to hear you're having issues.
Our tests aren't showing any obvious cause for this but we'll update the ticket on your account shortly.
 Matthew Wheeler
sub91
Just got told nothing can be done -_-
Fixes: 1,600
Apologies for the delayed response
Your speed is within the estimated speed range/expectations of your line. If your speed or estimates were higher previously, it's possibly the problem is caused by cross talk which is basically other connections being added to the cabinet.
