static ip
- Re: static ip
static ip
08-06-2019 5:34 PM
hi folks since readding the static ip address my ping results on the speedtests have doubled i used to get 7 ms on ping test now im getting 16 ms and these tests are done over ethernet connection and not wireless
if this is something to do with the static ip address can u fix this problem please as my daughter is a gamer and obviously the lower ping rate was what she wanted
thanks
Re: static ip
09-06-2019 10:01 AM
Hello @iangilf,
Thank you for getting in touch.
I'm afraid that having a static IP address would mean the service is routing traffic differently to that of a dynamic IP address. 16ms ping is still a low latency result but this will be solely down to the difference in hops to the end address. If you don't need the static IP address for a specific reason for example IP cameras, SSH or file servers, I'm happy for you to remove it and we will refund you the one off £5 charge.
Thanks again.
