speed
alb
speed
i up graded to 54 ...70  speed  ,,, and just getting  50 ,,,  called  waited 15 mins was told thats it fixed and still getting 50   grrrrrr
Fixes: 167
Re: speed
I can see from your estimates that your line should be connecting through to the cabinet between 53.5 and 70.7Mb/s
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 70.7 53.5 20 16.3 -- Available -- --
Your line is currently connected at 55.4Mbps, so is within the estimates although towards the bottom end.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 55.4 Mbps
Upstream Speed 20.0 Mbps
I appreciate that you may be getting 50Mb/s on a speedtest, however the estimates are based on the raw connection speed shown above.
Have you ensured that you are connected through to the master socket, no extension leads in place?
 Chris Parr
 Plusnet Staff
alb
Re: speed
hi chris, just a word i didnt pay for speeds of less than 54 or more than 70,  and i certainly dont pay for  51,  why dont you turn it up so i get what im paying for  if you dont then  we will take this further  i was promised speed  and not within range doesnt cut it , t a alb
Fixes: 167
Re: speed
Your speed and connection is within the estimates we provided.
That's not possible, the speed is governed by the line quality and length from the exchange.
As mentioned, your line is connecting within the speeds we advised.
 Chris Parr
 Plusnet Staff
