speed limit check
FIXED- Subscribe to RSS Feed
- speed limit check
30-05-2019 3:34 PM
Hi!
Now that the good weather has arrived, my d/l speeds are rock solid. However the downstream data rate appears locked at a constant 43.999 Mb/s. Never varies. This precise figure seems to imply limiting in action.
Could PN kindly have a check and determine any likely cause, please?
Best Regards, Jeff
(Formally, I was used to 54-55 Mb/s).
Fixed! Go to the fix.
30-05-2019 4:29 PM
Hi Jeff.
Cheers for getting back to us.
It has indeed, it's weather for shorts!
Moving on... testing your line is showing your speeds to be restricted at 44mbps. As the tests aren't showing any causes for this, I've passed this onto a colleague to arrange for your line to be reset again.
I'd allow 2-3 working days for this to be processed.
Let us know how it goes.
Re: speed limit check
03-06-2019 4:14 PM
Hi Gandalff and Guys!
Thanks so much for prompt support and resolution of my speed cap. Now humming at 53 Mb/s.
Superb response!!
03-06-2019 4:18 PM - edited 03-06-2019 4:18 PM
