speed issues
Stevieag
speed issues
As can be seen there what appears to a speedy BB connection.
The problem I have is that it is up and down.
I am working from home and to ensure i have the best i can get if people are using the connection I have a direct cable to my router/switch.
I can go a few days without an issue and then drop out continually. During these tests no one else was using the network.
What can be seen is the stop/start nature of the connection and the variability of this.
To give a real would explanation, a video call will be HD and then drop to low or stop, Youtube will drop to low def or twitch would stop/start.
I dont use great levels of traffic for work except for video every so often but if ssh'ed into a remote server i will get dropped connections 😮
Could there be anything yourside that is the issue?
I dont get issues tethered to a mobile connection 😕
2 REPLIES 2
Stevieag
Re: speed issues
So i can get the extra speed tests up CheesyCheesy
You can see its all over the show, i do appreciate that different tests may give different results but most use ookla plus id expect somewhere near on the same test infra ie BT v BT, ookla v ookla
Stevieag
Re: speed issues
63 views and no help... 🤔🧐
I appreciate it's a hard one and the images of speed tests appear to have a good connection but tonight I'm unable to watch YouTube, today at work can't zoom, whilst learning on udemt I was losing connection, I now have had to resort to special software to retain a SSH session.
There is definitely something wrong
