speed dropped and pings raised
iangilf
hi folks since the bad weather my speeds have dropped nearlly 15 meg over night and my pings have increased from 1 to 22 ms
current stats
6. Data Rate: 20000 / 64229
7. Maximum Data Rate: 20826 / 79292
8. Noise Margin: 6.5 / 6.2
9. Line Attenuation: 17.0 / 14.1
when i turn router off and on it just comes back up at 64 meg
i usually get the full 80 or 76 meg
im sure dlm has kicked in now but why has the weather changed this so much ?
thanks folks
been with plusnet ages now
6 REPLIES 6
iangilf
Re: speed dropped and pings raised
Few people have viewed this but no reply ?
adamwalker
Fixes: 221
It may be that there's an issue with a joint somewhere in the line where water ingress might be having an effect.
Assuming that you have a phone handset plugged in do you hear any noise?
 Adam Walker
iangilf
Have tried handset and right now seems clear mate
iangilf
can i have another line check please
3. Firmware version: Software version 4.7.5.1.83.8.226 Last updated 29/09/16
4. Board version: Plusnet Hub One
5. DSL uptime: 8 days, 01:10:24
6. Data rate: 20000 / 74714
7. Maximum data rate: 27182 / 73892
8. Noise margin: 9.4 / 5.7
9. Line attenuation: 17.2 / 14.0
10. Signal attenuation: 17.0 / 14.0
iangilf
customer and tech support sucks on plusnet noone helping and this community certainly dont help what a waste of time raised tickets to and noone helps what a joke this all is
im glad virgin media is being laid so will be changing over to that when it goes live
iangilf
3 power cuts in a row where i live and my router was on for nearly 19 days without a drop out
it came back on after 3 power cuts in a row in the area i live in and my stats are
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ54605283
3. Firmware version: Software version 4.7.5.1.83.8.237.2.2 Last updated 11/12/17
5. DSL uptime: 0 days, 00:36:53
6. Data rate: 20000 / 77050
7. Maximum data rate: 27814 / 75521
so went up but the maximum data rate hasnt but the data rate has weird
